Addin Calculation button not working in MSP Addin
I need to use RiskyProject management meeting for next week. It is not working. I cannot get the Addin to do the "Calculation" . i can get the file to work, but I cannot run a simulation. I don't have the Desktop version of MS Project anymore. When I got the cloud version, the desktop version or RiskyProject disappeared.
Re: Addin Calculation button not working in MSP Addin
With the update to the MSP cloud the communication between the addin and the calculation engine appears to be blocked or getting interrupted and the calculation is failing. It is an odd situation, because the Addin doesn't work independently of the desktop software as they share the calculation engine. In addition, for the Addin to appear in MSP, the desktop has to be installed on the Windows OS. Until your IT team can resolve the issue the best workaround is to export the files as an xml and then manually launch RiskyProject from the install folder and import the xml. The default location is C:\Program Files\Intaver\RiskyProject 7.2\RiskyProject.exe.
