Input Distribution Chart
You can  view an enlarged input distribution chart when you double-click on the small distribution chart on the Distributions tab of Task Information dialog box.
You can use the  input distribution chart to view  and enlarged probability density function. Axis X of the function represents actual value (duration, cost, income, or start time). Axis Y represents probability.
Use short cut menu to:
  • Copy chart to clipboard as metafile
  • Copy chart to clipboard as bitmap
  • Copy chart to the file in JPEG format
Defining task distributions
Adding 3-point estimates
