Project Risk Analysis Solutions
Project Risk Analysis with Microsoft® Project
RiskyProject is seamlessly integrated with Project 2003 and higher. When RiskyProject is installed it checks if Project is installed on the computer and adds a RiskyProject toolbar and macro to Project. Using this toolbar you may transfer your project schedule to RiskyProject, add risks and uncertainties and perform the analysis. Your schedules in Project and RiskyProject are fully synchronized: if you change schedule in Project it will be reflected in RiskyProject. Risk and uncertainties defined in RiskyProject will be linked to your Project schedule. Click here to view demo
Project Risk Analysis with Oracle® Primavera
Primavera is one of the leading project management software developers. RiskyProject is designed to easily integrate with Primavera Project Management software. RiskyProject can read project data created in Primavera and perform quantitative risk analysis on your project. Results of analysis can be exported back to Primavera software. RiskyProject is also integrated with Primavera's SureTrak. SureTrak can be launched directly from RiskyProject.
Project Risk Analysis with MindView by MatchWare
MatchWare is a leading provider of multimedia, screen recording and visual thinking software that enhances individuals' ability to create, visualize, manage and distribute information. MatchWare's MindView 3 Business is a professional mind mapping software application that allows users to brainstorm and visualize ideas quickly and easily. The integrated solution of MindView and RiskyProject can be used to define a project plan, assign risks and uncertainties, and perform quantitative risk analysis
Project Risk Analysis with AuroraTM by Stottler Henke
The Aurora(TM) intelligent project scheduling software combines a variety of scheduling techniques, intelligent conflict resolution, and automated decision support to generate shorter schedules for resource-constrained critical-path projects. Almost 20 years of R&D have gone into Aurora's development, mostly to meet many of NASA's toughest planning & scheduling challenges. Aurora also includes the world's most advanced multi-project Critical Chain implementation. Aurora's scheduling engine can be seamlessly integrated with off-the-shelf scheduling tools (e.g., Primavera, MS Project, Deltek Open Plan); and can read and write data to RiskyProject.
Project Risk Analysis with Safran® Project
Safran Project is developed and designed to handle the demands of large and complex projects. With Safran Project, an organization is capable of executing and managing all types of projects. The software has been developed in collaboration with project managers within a sector that has strict requirements towards project control tools. RiskyProject an perform risk analysis using project schedules created in Safran Project.
Decision Analysis for Projects (Integration with Vanguard Studio)
You project has a number of alternatives. During the course of a project, you can make different decisions, which may significantly change the project. Moreover, your project is also affected but a number of risks and uncertainties.
- What particular project scenario should be selected?
- How will this selection be affected by risks and uncertainties?
- What actions should be taken if something changes in the middle of the project?
This decision analysis solution for project schedules will help you to answer this and other questions. RiskyProject Professional allows the user to perform an analysis of different scenarios using decision trees. Decision trees can be created based on RiskyProject's project schedule and presented using Vanguard's DecisionPro software.
Project Risk Analysis with FastTrack
AEC Software's FastTrack Schedule 10 makes it easy to organize, track, and manage all project details. RiskyProject integrates with AEC Software's FastTrack Schedule 10 using an XML interface. Just export FastTrack's project schedule into XML format and open it in RiskyProject. You can then assign risks and uncertainties and perform quantitative risk analysis on the project. In this way, you can analyze the risk profile of FastTrack's schedules.
WBS Chart Pro and PERT Charts
WBS Chart Pro and PERT Chart Expert are used to present and modify project schedules in two different graphic formats. This software has been developed by Critical Tools. Both of these applications can be launched from the toolbar or from the menu.
Project Risk Analysis with WelcomRisk
WelcomRisk is an enterprise qualitative risk management software. WelcomRisk allows you to identify and register risk, assign them to projects and activities, and track risks and mitigation efforts. List of activities can be created in WelcomRisk or imported from other project management software. RiskyProject can import data from Welcom Risk using the WelcomRisk wizard and perform quantitative risk analysis. Integration of WelcomRisk and RiskyProject allows you to perform analysis based on properly managed reliable risk databases. It helps to mitigate psychological biases, related to estimations of risks and uncertainties (see Event Chain Methodology).
Project Risk Management Planning with Project KickStart
Project KickStart from Experience In Software, Inc. Project KickStart is the fastest, easiest way to plan and schedule projects. It's unique in the world of project management tools, focusing on both planning a project and building a Gantt chart schedule. Project KickStart's 8-step planning icons focus your attention on the project structure -- goals, resources, obstacles and other strategic issues critical to your project's success. RiskyProject can use project plan created in Project KickStart. Moreover, results of the analysis can be imported back to Project KickStart. Project KickStart can be launched directly from RiskyProject.
Project Risk Analysis with Intellisys Project Desktop
Intellisys Project Desktop from Intellisys Inc. project management software lets you manage your projects from Mac, Linux, Unix or Windows. Access your projects from any location through a powerful interface. Enjoy transparent enterprise wide resource management and scheduling. Provide clients direct access to project status. Get all the features you really want, including WBS, Gantt charts, Pert Charts and more, without being distracted by features you don't need.
RiskyProject can use a project schedule created in Intellisys Project Desktop to perform decision and quantitative risk analysis. Moreover, results of the analysis can be imported back to Intellisys Project Desktop.
Project Risk Analysis with Sciforma PS8
Dedicated to building innovative features within its software since 1982, Sciforma's PS8 provides the first PM software to fully implement Theory of Constraints and Critical Chain. PS8 capitalizes on over 20 years of experience in providing project management solutions in all areas of industry and government, including manufacturing, information sciences, construction, telecommunications, and research and development. From the smallest marketing campaigns to the largest space program, PS8 provides an abundant of features to keep your projects on schedule and on budget.
RiskyProject can use a project schedule created PS8 in to perform decision and quantitative risk analysis. Moreover, results of the analysis can be imported back to PS8.
Project Decision and Risk Analysis with MindManager
MindManager is the visual tool for planning, collaboration and business process management. The integrated solution of MindManager and RiskyProject can be used to define a project plan, assign risks and uncertainties, perform quantitative risk analysis, and present results of probabilistic analysis in MindManager. Moreover; if you have RiskyProject Professional and Vanguard's DecisionPro, you can perform a decision analysis: select a project alternative based on the plan created in MindManager.
Project Risk Analysis with TurboProject
TurboProject is a project management application for planning and managing simple and complex projects. RiskyProject can use a project schedule created in TurboProject to perform decision and quantitative risk analysis. Moreover, results of the analysis can be imported back to TurboProject. TurboProject can be launched directly from RiskyProject Professional and RiskyProject Lite.
Project Risk Analysis with Milestones
Milestones by Kidasa Software Inc. is a project management and data presentation. Integrated RiskyProject/Milestones solution allows the project manager to produce presentation reports from RiskyProject schedule, manage large projects and coordinate team projects, format schedule to meet any reporting needs, publish the schedule on Internet.
RiskyProject can use a project schedule created in Milestones to perform decision and quantitative risk analysis. Results of the analysis can be imported back to Milestones.
Financial Analysis and Fiscal Modeling with Great Budget
Great Budget is the tool to rapidly build project budgets and integrate cost/ risk into the decision making process. Great Budget includes automatic budget calculating, advanced monitoring and tracking and CRIMS technology for risk identification and management. These technologies simplify budget building and validation and offer transparency for accurate cost estimation and management.
RiskyProject can use information defined in Great Budget to perform project risk analysis.
