Setting up
risk defaults
You
define defaults for Global and Local risks in the Risks tab. These
parameters are used when you create a new risk.
2. Click the Risk tab.
3. Enter the default settings for the chance of:
• risk occurrence
• type of outcome
• result of outcome.
The result of outcomes is used to calculate outcomes for
Relative Delay and Cost or Income Increase, as well as all user
defined risk outcomes for non-schedule risks.
4. Select the default distribution for the moment of risk. This
distribution is used to define when risk would occur during the
course of project. It is defined by distribution type (uniform or
triangular), and three parameters defining start, most likely, and
finish time of risk occurrence expressed as a percent of total task
duration starting from the beginning of the task. For example:
• Distribution: Triangular
• Start: 50%
• Most likely: 80%
• End: 100%
In the above case, the default for new task with duration 10 days
risk would occur after 5th day, but most likely would occur on 8th
day.
5. Select the risk chance option. The chance can be defined per task
(by default) or per duration unit. For example, 30% chance that task
can be restarted per day. If task duration is 2 days, chance of risk
occurrence per task will be 60%. This option works for all projects.
You cannot have different risks with chance applied to the duration
unit or chance applied to the complete task for the same project at
the same time.
