Task Simulation Results for Cost, Revenue and
Income
RiskyProject allows you to quickly view the cost, income, and
revenue, if income
in any task is defined.
After you have completed a probabilistic calculation, you can see
probability that the particular task will have a cost, an income,
and a revenue less than a
certain value.
Viewing Task Simulation Results
1. Drag the slider across the charts to view the chance of a certain
result.
2. Double-click on a chart to open up a detailed view of the chart.
• Click the tabs on the top of the charts to toggle
between Frequency, Cumulative
Probability views, or their combination.
• Click the Statistics, Data,
or Percentiles to view more detailed views of the
result data.
• Double click on the frequency chart to
enlarge it
• Right-click on a chart to copy the chart, statistics or data
to the clipboard or view cumulative probability, frequency charts,
• You may format charts using Options button for short cut
menu.
See also Task
simulation results details Task
simulation results options
