Glossary
Current Schedule
The deterministic project schedule that is currently active and used for probabilistic calculations. In most cases, it is the original project schedule you created or imported from other project management software. You may also set a baseline, which you previously created. See 'Baseline Project Schedule (Baseline)' for more information.
