Cost Analysis View
Use the Cost Analysis view to analyze cost and income on each stage of the project. The Cost Analysis view has up to three cost diagrams:
Project Management: Cost and Revenue Analysis
You may use the slider to determine:
  • Cost Variance (actual vs. budgeted cost)
  • Cost with Risks and uncertainties vs. Current schedule (budgeted) cost.
  • If income is defiIf income is defined for at least one task, the cost analysis diagram will show the project Revenue calculated based on the formula: Revenue = Income - Cost.
  • If Cost exceeds Income in any given period of time Revenue will be negative.
  • If income is not defined, Cost will be always positive.
Use the shortcut menu to modify the chart. In particular, instead of showing a line chart of current schedule, result, and actual cost, you can present an area chart by choosing Fill Chart from the shortcut menu.
Cost and Income
Cost Reports View
