Copy Images to Clipboard and JPEG, BMP, PNG, GIF or TIFF file
When you click Copy Picture icon on the Schedule tab, Format group, the Copy Picture dialog box opens. You can define the following options:
  1. You may copy picture to clipboard as bitmap or metafile or you may copy picture to JPEG, PNG, TIFF, GIF or BMP file.
  2. You may copy only selected tasks.
  3. You may also specify a width of the output chart. RiskyProject will scale the output image so it will fit to this width.
  4. You may specify a number of columns of the datasheet to be presented on the output chart. For example, if you choose 2 columns for Gantt Chart view the output chart will include task ID and task name together with Gantt bars.
