How to define risk correlation
Risk correlations can only be defined in the risk tabs on Task Information and Resource Information dialogs.
  1. Double-click on the risk ID
  2. Click the Correlations tab.
  3. Select a risk from the list of all available risks.
  4. Select the task or resource to which this risk is assigned. This is required when risks with the same name are assigned to different resources or tasks.
  5. Click OK to save this information.
Risk Correlations
