Defining statistical distribution for risk outcomes
To enable probabilistic risk outcomes:
- Click the Schedule tab. In the Settings group, click Options.
- Click the Risk tab.
- Select the Enable statistical distribution for risk outcome checkbox.
Once enabled, this setting is the default for all RiskyProject files on your computer.
Click the Risks tab. In the Risk Views
group, click Risk Register.
- Open the Risk Information dialog box.
Click the Probabilities and Outcomes tab for qualitative
risk analysis (if you don'tr have project schedule) or Assign to tasks or
resources for quantitative analysis
Right click on risk alternative ID and select Distribution of risk
outcomes
Select the distribution from the Distribution list. If you select Undefined, the
base value will be used for all iterations.
Define the distribution parameters. The Probability Density chart is
automatically updated. You can adjust distribution parameters using the sliders.
If you use a custom or discrete distribution, a grid opens. The grid will allow
you to define points (or intervals for discrete distributions) and associated
with each point (interval).
If you select Normal or Lognormal, you must select
the Low and High probability range (P1 and P99, P5 and P95 or P10 and P90).
These are "cut-off" parameters; meaning that duration, cost, or start time
cannot go beyond these values.
If you perform qualitative risk analysis in Risk Register you can view:
Impact (pre-mitigation or post-mitigation) for all categories: it is calculated as mean value of you have for
probabilistic risk outcome.
Impact for individual categories (e.g. Impact: Cost or Impact: Schedule): it is input base value of Outome
About Risk Assignments
