Distribution Fitting using Stat::Fit
If you have empirical data for Cost, Income, and Duration, you may
use Stat::Fit software to generate most appropriate statistical
distribution. You cannot use Stat::Fit for start time. Stat::Fit is
the third party software by Geer Mountain Software (www.geerms.com)
and can be purchased separately.
Fitting a distribution
- Click the Distibutions tab in the Task Information
dialog box.
- Click on the Fit Distribution
button. The Stat::Fit software opens.
- Enter data to the Data Table. Make sure that you
are entering data in the current units for RiskyProject e.g. days
- Click on the Auto::Fit toolbar button
- Select a recommended distribution from the list of possible
distributions. Make sure that RiskyProject supports distribution you
selected. RiskyProject can use only Uniform, Normal, Lognormal,
Beta, Gamma, Triangular, and Exponential distributions from
Stat::Fit.
- When you are satisfied with selected distribution, click the
Export button. From the list of applications,
select RiskyProject. Output should be set to Clipboard
(default selection).
- Click OK.
- Save empirical data in Stat::Fit if you which and close
Stat::Fit. RiskyProject will generate distribution and assign low
and high estimates for cost, income, and duration based on empirical
data.
Distributions for 3-point estimates
Adding 3-point estimates
