Setting up reports
You can set up how you want your to print from all views with the exception of the Resources.
  1. Click  File and then Page Setup. The Page Setup dialog box opens.
  2. Enter the page margins in the Margins group box.
  3. If you want to include a footer, select the Draw Footer check box.
  4. Select the checkboxes associated with the information you want to include in the header.
  5. If you want to include a header, select the Draw Header checkbox.
  6. Select the checkboxes associated with the information you want to include in the footer.
  7. If you only want to include headers or footers on the first page, select the Draw on first page only check boxes.
  8. Click either the Landscape or the Portrait page orientation option. If you want a page border, select the Draw page border checkbox.
  9. Adjust the height of each item (row) in the Height of one item box.
  10. Select the number of columns to print from the Print box.
  11. Select the view from the columns for view drop-down list.
  12. Click OK.
Reports
