Viewing Statistical Results
for Work
- In the Task Information dialog click the Resource tab.
Right click on resource ID and select Simulation Results
Drag the slider across a chart to view the chance that the work will equal a certain value.
View statistical parameters, percentiles, and raw statistical data for work on
the left pane
- Switch between frequency chart, cumulative probability chart, and combined chart on the right pane of the dialog
- Right-click on the chart to view a full menu of analysis and copying options.
The low and high results of probabilistic calculations (cost, duration, and finish times) are
associated with P1/P99, P5/P95, P10/P90, or any custom percentiles. These are
defined in the Options (Calculation tab).
You may customize frequency charts either using Risks tab > Format Chart or by
right clicking of frequency chart and selecting Options.
Task Simulation Results
