Changing Risk Visibility
After a risk is created, you may change the list of projects within which the risk is visible.
To change risk visibility:
- Click the Risks tab and then in the Risk Views group,
click Risk Register or Risky Properties.
- Double-click on a Risk ID to open the Risk Information
dialog box.
- Click the Properties tab.
- Select a visibility level. You may choose to make this risk visible:
- For all projects/all levels of the hierarchy
- Only at the enterprise level of the hierarchy
- For specific projects
- If you need to make your risk visible for a particular project, click
Specific Projects and then the Select Projects button.
The Risk Visibility dialog box will open.
- Select projects in which you would like your project to be visible.
- Click OK.
About Risk Visibility (Approval) Rules
Risk Visibility vs. Risk Assignment
