DCMA Check #9B: Invalid Actual DatesThis check calculates percentage of Incomplete Tasks with Invalid Actual Dates: Task's Actual Start or Actual Finish after Project Status Date. Project Status dates is defined in Project Settings dialog (Schedule tab) or imported from other software, such as Microsoft Project or Primavera. Project Status date may be not defined. In this case this check will not be conducted. This check indicates how well the project schedule is updated with actuals. FormulaTargetPercent of incomplete tasks with Invalid Actual Dates should not exceed 0% CommentsUsing list of task issues (the list at the top of Diagnostics dialog box) you can find tasks with "Actual Start or Actual Finish after Project Status Date". See also |
