Project defaults are global project settings. There are two types of
defaults:
Project Options These options are
applicable to a particular project and are saved in the project
file. You define project options on Tools -> Options.
Global Options - These project defaults are
applied to all new projects and are saved in the system registry.
Global options include default risk properties, default risk
outcomes, and default values of project options. You save global
options clicking on Set as default in the tabs that support defaults
in the Options, Risk Outcome, and Risk Properties dialog boxes.
The Options dialog box includes seven tabs. Use the:
View tab to setup general project parameters and how project
desktop will look like
Duration tab to define calculation of task durations
Calendar tab is responsible for calculation of project
schedule
Units tab defines how time units are displayed or input
Cost tab is responsible to default cost parameters and
calculation
Tools tab define path for the external applications
Setting
up your projects
