Adding fixed costs and income to tasks
1. On the Workflow bar, click the Cost
Analysis view.
2. Select the task in which you want to fixed costs.
3. Enter base fixed cost in the Cost field. You can
enter in Low and High estimated costs.
4. Select an accrual method in the Accrual column.
Accrual methods indicate how cost is accrued in the task. Default
accrual method if defaulted in Tools ->
Options, cost tab separately for cost. Accrual methods
available are:
• Start
• Finish
• Prorated
5. Enter Income in the same manner as above.
You may assign fixed cost to the summary tasks the same way as they
are assigned to the subtasks
• You may define uncertainties in fixed cost using low, base
and high values of cost.
• Uncertainty in variable cost is originated in task work
since variable cost = resource work * number of units * rate.
Analyzing Cost and Revenue
Cash Flow Analysis
