Assigning local and global risks the Global Risk Assignment view
This is a preferred method for global risk assignment. You may use
this method for assigning local risks based on global risks. If you
have global risks, you may assign it to one of many task and
resources at the same time.
1. On the Risks tab of the Workflow
bar, click the Global Risk Assignment view.
2. Click on the first row.
3. Select the risk that you want to assign as a global risk.
4. Select whether this is a global task or resource risk.
5. Enter the Chance, Outcome, and
Result of the risk.
6. Select the Moment of risk distribution from the
drop-down list. If it is triangular, you must define the Start, Most
Likely, and Finish parameters. Monent of risk is available in
RiskyProject Professional only.
7. Click the Enable check box to enable the risk
for purposes of calculation.
8. Repeat steps 2 -6 to add additional global risks.
Assigning risks from the Global Risk Assignment view to
local tasks or resources
You may also use the Global Risk Assignment view to assign local
risks.
1. Open the Global Risk Assignment view.
2. Define a new risk assignment or select existing risk assignment.
3. Double click on the Risk ID field. The Risk
Information dialog box opens.
4. Select either the Assign to Tasks or
Assign to Resources tab.
5. Select a task or resource from the list.
6. Enable or disable risk for the particular task or resources if
necessary
• If you enable a risk and assign it to a task using the
Global Risk View, ensure that in Global Risk view the risk is
disabled. Otherwise, risk may occur twice as global and as local
risks.
• You can update the risk properties for all of the tasks and
resources to which this risk is assigned using the Update Risk
Properties button. For example, you can update a risk in the Global
Risks Assignment view. Then select the Assign to Tasks or Assign to
Resources tab and click the Update Risk Properties button .
