Copy
Images to Clipboard and JPEG file
When you click on Copy Picture icon within a Standard toolbar, copy
picture dialog box comes up. You may define the following options:
1. You may copy picture to clipboard as bitmap or metafile or you
may copy picture to JPEG file.
2. You may copy only selected tasks.
3. You may also specify a width of the output chart. RiskyProject
will scale the output image so it will fit to this width.
4. You
may specify a number of columns of the datasheet to be presented on
the output chart. For example, if you choose 2 columns for Gantt Chart
view the output chart will include task ID and task name together with
Gantt bars.
To export data to clipboard separate DLL (RiskyProjectJPEG.dll) is
used. The DLL is registered during installation. If the DLL is
missing or not registered, you will not be able to create JPEG
files.
Reports
