Back to RiskyProject Professional
Field Descriptions
Tasks
 Actual Income
 Actual Cost
 Display Tracking Chart Checkbox
 Task Duration Low – current schedule
 Duration High
 Duration High Result
 Task Duration Low – Results
 Duration Mean Result
 Duration Mean Statistical Result
 Effort Driven Task check box
 Finish Time High Result
 Finish Time Low Result
 Finish Time Mean Result
 Fixed Cost Accrual
 Fixed Cost - Base
 Fixed Cost - High
 Fixed Cost - Low
 Ignore Resource Calendar
 Income Accrual
 Income Base
 Income High
 Income High Result
 Income Low
 Income Low Result
 Income Mean Result
 Milestone Check box
 Notes
 Percent Completed
 Present Task on the Risk Chart
 Resource Cost Base
 Resources
 Revenue Base
 Revenue High
 Revenue Low
 Revenue Mean
 Seed for Monte Carlo Simulation Duration
 Seed for Monte Carlo Simulation Fixed Cost
 Seed for Monte Carlo Simulation Income
 Seed for Monte Carlo Simulation Start Time
 Sensitivity Coefficient Cost
 Sensitivity Coefficient Duration
 Show Risk Table Flag
 Start Time High - resultg
 Start Time Low - result
 Start Time Mean - result
 Start Time Task Base
 Start Time Task High
 Start Time Task Low
 Statistical Distribution for Duration
 Statistical Distribution for Fixed Cost
 Statistical Distribution for Start Time
 Success Rate
 Task Calendar
 Task Name
 Total Cost (Base)
 Total Task Cost High - result
 Total Task Cost Low - result
 Total Task Cost Mean - result
 Work Base – cur. schedule
 Work High – cur. schedule
 Work High Result
 Work Low – cur. schedule
 Work Low Result
 Work Mean Result
Resources
 Base Calendar
 Draw chart
 Material label
 Maximum units
 Actual Income
 Resource description
 Resource Initials
 Resource Name
 Standard Rate
 Type
Risk
 Risk Assigned to Task/Resource
 Chance that risk will occur
 Color for probability wheel
 Distribution
 Distribution Chart
 Finish time of the risk occurrence
 Most likely time of the risk occurrence
 Outcome of the risk
 Result of the outcome
 Risk Alternative
 Risk Description
 Risk Enabled
 Risk Impact for Cost
 Risk Impact for All Parameters
 Risk Impact for Duration
 Risk Mitigation Plan
 Risk Name
 Seed for outcome
 Seed for outcome
 Start time of the risk occurrence
Sensitivity
 Impact (current schedule)
 Impact (Post-mitigation)
 Impact (Pre-mitigation)
 Note
 Opened or closed risk
 Parameter Name
 Parameter Type
 Probability (current schedule)
 Probability (Post-mitigation))
 Probability (Pre-mitigation))
 Risk or Issue
 Score Current Schedule
 Score (Post-mitigation)
 Score (Pre-mitigation)
 Sensitivity Chart
 Show risk on the matrix
 Task ID
 Threat or opportunity (current schedule)
