Managing Resources and Work
Resources are the people and equipment that are assigned or the
material that is used to complete a task.
Adding resources
1. On the Workflow bar, click the Resources
view.
2. Click on a row.
3. Provide a Name (mandatory), Initials
(optional), and Rate (mandatory).
• You can group resources to define reams using the
indent and outdent buttons.
• Initials and notes are for information only and do
not affect the calculations.
• Rates affect the cost the task to which the resource
is assigned. Rates for work resources can be per year, month, week,
day, hour and minute. Rates for material resources are per unit
(e.g. 10 tons).
4. Select the resource type: Material or
Work.
• Material label indicates type of material resources
(e.g. tons)
• Maximum units are used to calculate Overallocation of
work resources. It is not used for the material resources.
Use the Resource Information dialog box to assign resources risks.
• You can add risks to a resource using the Risk tab of
Resource Information dialog box. If you have only a few risks
assigned to a few resources, this is the preferred method to define
resource risks. If you have many resources, we recommend that you
add the risks in the Risk Register of Risk workflow tab and then
assign them to the resources from one of the risk views.
• Default rate for resource type Work is defined in
Tools->Options Cost tab.
Cost Rate Tables
Resource
Information Dialog
