Setting up project management tool integration
You define the path for the external applications in the Tools tab.
This tab is useful if you have removed an external application or a
new release of the external application is installed and
RiskyProject cannot find it in the registry. You can also use the
Tool tab to correct a path if you selected the wrong file for
external application.
2. Click the Tools tab.
3. Click the Browse button to browse for the
application executable and enter in the URL of the application
vendor.
4. Click OK to save the project defaults..
