Setting up viewing defaults
Use the View tab to setup general project parameters and modify the appearance of the RiskyProject workspace.
2. Click the View tab.
3. Enter the default project information (i.e. Project Manager) in the text boxes. You can view them in the Project Results view and Main Project Settings dialog box next time you create new project. The Project Manager box is also used as a default value for risk properties: recorder, owner, and contact.
4. Select the project view that will appear whenever RiskyProject is opened from the Default View list. ***LAST VIEW*** will automatically load the most recently open RiskyProject session.
5. Select or clear the Show or hide startup view check boxes to enable or disable the workflow bar, legends, and splash screens.
6. Select the data type option that you want to use when you export project files to 3rd party tools or to MPX file. When you perform export data to 3rd party tools, such as Microsoft Project, you will be given two options:
     export current project schedule
     export results of probabilistic analysis
7. Here you can choose a default selection. You may also choose not to present this selection before export data to the 3rd party tools or MPX software. In this case, the default selection will be used.
All viewing defaults are global, so they are applied to all new projects created on this computer.
www.intaver.com products solutions support partners technology company
