Adding risk properties
Risk properties are attributes that can be used for filtering or
searching. While some properties are populated automatically (e.g.
Creation Date), you can enter specific values as required. You
define default risk properties in the Default Risk Properties dialog
box accessible from the Risk menu.
1. Open the Risk Register.
2. Double-click on the risk ID to which you want to add properties.
3. Click the Properties tab.
4. Add a description in the Description box.
5. For each property, add a value as required.
Risk properties do not affect calculations, including risk ranking,
cost, duration, etc. For example, the risk property “Potential Loss
in Monetary Terms” does not affect cost calculations.
Risk Register
Adding risk categories
Adding risk outcomes
