Defining work for task types
You can enter tasks as work rather than duration. The Work view shows
the total work of all resources assigned to a task.
1. On the Workflow bar, click the Gantt
View.
2. Insert columns:
• Effort Driven
• Task Type
• Work low (current schedule)
• Work base (current schedule)
• Work high (current schedule)
3. Select the Task type: fixed
units, fixed duration, or fixed work. You may also select units in
task tab. The same information can be defined using Advanced tab of
task information dialog.
4. Check the Effort driven flag if
the task is effort driven (default value). Effort driven flag can be
defined using Advanced tab of task information dialog.
4. Enter low, base, and high work for the selected task. Units for
work are defined in the Tools > Options>
Duration tab. Duration and units for the task will
be calculated based on task type.
Defining working time
