Editing Risk Properties
1. On the Risk menu, click Default
Risk Properties.
2. Select a row under which you want to add a new risk property.
3. Right-click on the row number and choose New
Property Item.
4. Type in a the name
5. Select type, maximum and minimum values for the new property
6. Use the Indent and Outdent arrows to create groups of risk
properties.
Default risk properties are automatically saved in the system
registry and can be used for all projects. You may use Restore
Default button to overwrite changes in default risk properties you
made with standard set of risk properties
Managing
Default Risk Properties
