Formatting the Risk Matrix
You can modify the risk matrix labels and the risk tolerance display.
The level of risk tolerance is shows using color-coding (for
threats: green: low risk, yellow: medium risk, red: high risk). A
high number of green cells on the chart indicates a high risk
tolerance. A high number of red cells on the chart indicates a low
risk tolerance. Color-coding for opportunities is the opposite. If
risk is both a threat and opportunity, the color is not defined.
1. On the Format menu, choose Format
Risk Matrix.
2. Modify the Impact and Probability
labels as required.
3. Drag the Risk Tolerance slider to the left to
set a low risk tolerance or to the right to set a high risk
tolerance.
Labels for risk impact are used to describe the result of
non-schedule risk outcomes. For example, if you have risk with the
outcome “Legal Problems” and result of this outcome 20%, the
description would be Low, which comes from the risk impact label.
Risk Matrix
