About the RiskyProject Enterprise Sample Database
Download the RiskyProject Enterprise sample database to learn how to use RiskyProject Enterprise with RiskyProject Professional, RiskyProject Lite, and Risk Project Risk Register clients. The sample database contains an sample project portfolio, which programs, projects and with risk and other project data. You can create it using SQL scripts for Microsoft SQL Server (2005 and later). The easiest and quickest way to create the database is to use the RiskyProjectDB.exe tool, which comes with the RiskyProject installation. You can find information on how to use the RiskyProjectDB.exe utility in the RiskyProject Administrator’s Guide. You may also run this script using Microsoft SQL Server Management Studio.
